b series starters
Old Oct 20, 2004 | 08:02 PM
ghettoklepto's Avatar
ghettoklepto
Default b series starters
does it matter what year ls starter i use as long as its manual for a b18b with gsr tranny obd2. are the starters obd1 obd2 specific?
Old Oct 20, 2004 | 08:05 PM
ghettoklepto
1 more question will a obd2 gsr dizzy work with my b18b>?
Old Oct 21, 2004 | 11:25 AM
ISP James's Avatar
ISP James
DAMIMRED
hey other guy from the MSI forums :wavey:
Old Oct 21, 2004 | 11:51 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Im using and OBD1 b16 starter on my LS OBD2 tranny. So to answer your question it will work as long as its manual
Old Oct 21, 2004 | 11:53 AM
teg92's Avatar
teg92
WHAT OK YEAH!
I dont think it will cause the GSR has vtec But Im not 100% sure
Old Oct 23, 2004 | 10:16 AM
Kai's Avatar
Kai
Rotorphile.
No, one of the three mounting points is different on the GS-R unit to make room for the VTEC solenoid.
I guess you could theoritically modify it by removing that leg as you would to use a non-VTEC distributor on a VTEC head, but I really don't see the point. You can sell yours for more then an OBD-2 B18B dist. is worth and buy a proper one.
Old Oct 23, 2004 | 06:16 PM
dustimus's Avatar
dustimus
Better golfer than you
Thats funny because right when I shipped it out I was thinking if it would work with your B18b
Old Oct 24, 2004 | 12:03 AM
Kai's Avatar
Kai
Rotorphile.
Upon reviewing this thread, any 92+ starter will work. 91 and older flywheels where a different size, and will not work with later model B-series starters... just on a side note.
