gsr fan not spinning
Old Oct 4, 2004 | 09:47 PM
alex_f15's Avatar
alex_f15
Default gsr fan not spinning
my gsr radiator fan not turning on and my car gets overheat
what can cause the fan not spinning?
Old Oct 5, 2004 | 07:06 AM
JimBlake's Avatar
JimBlake
What year GSR?
Fuse?
Relay?
Fan switch?
Bad motor?
On my '95 the fan switch is in the thermostat housing, it's got a 2-wire plug. Unplug it & jumper the wires with a paper clip. If that makes the fan run (key on) then all the other stuff is OK & you need a new fan switch.
qtiger's Avatar
qtiger
Bad fan switch
