Gsr In EG...
Old Sep 26, 2004 | 11:31 PM
SiHatchR6's Avatar
SiHatchR6
Default Gsr In EG...
Got a 95 si hatch and want to swap a gsr motor. Im sure its been asked many times but did a search and didnt come up with what I was looking for. I need to know everything that I will need to complete this. So far im hearing it almost direct drop in and bolt up except for the harness. But key me in on what shift linkage I need, what ECU I need, will I need gsr axles?, and what harness I need and so on. Oh and are the gsr motors OBD1? Thanks.
Old Sep 27, 2004 | 06:15 PM
j87w's Avatar
j87w
The 94 and 95 gsr is obd1. Youll have to use a GSR ecu because they have a dual stage intake runner system. Youll have to use the 94-01 Integra shift linkage. I would just use your harness and make it fit(change some plugs and lengthen possibly).
Oh and youll want to use a 94 to 95 GSR OBD 1 ECU. The axles you will most likely just use gsrs. If im wrong someone correct me.
Old Sep 27, 2004 | 06:28 PM
Civic2Scooby's Avatar
Civic2Scooby
use your Si harness and just transfer it over to the GSR motor
you will need:
B series motor mounts
B series shift linkage
B series rear tranny mount bracket
GSR throttle cable with firewall support bracket
GSR axles and half shaft
obd1 GSR ecu
wouldnt hurt to upgrade to a dual core radiator, or a teg radiator.
also need to add a couple wires to your ecu plug
only wire you will need to lengthen will be the O2 Sensor wire.
Old Sep 28, 2004 | 09:27 AM
SiHatchR6's Avatar
SiHatchR6
All right thanks guys. One more question though. Of the extras that you listed how much do you think I can get all that stuff for if I shop around?
