How to identify the JDM DOHC ZC engine
Old Sep 2, 2004 | 09:29 PM
gh3ttotactic's Avatar
gh3ttotactic
Blue Member
Default How to identify the JDM DOHC ZC engine
I'm going to buy a JDM DOCH ZC engine and ECU tomorrow for a swap. I don't need help on the ECU, but how do I identify the JDM DOHC ZC engine ?? I know it has a Dual Cam, but what else should i look for ?? Any engraving or # i should look for ??
Old Sep 3, 2004 | 11:27 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
well, I mean an extra cam is pretty easy to spot.. bigger valve cover and such... that should be a pretty dead giveaway.
Old Sep 7, 2004 | 09:29 AM
Kai's Avatar
Kai
Rotorphile.
The "ZC" stamp on the block makes it pretty obvious.
Old Sep 7, 2004 | 08:40 PM
TekScream's Avatar
TekScream
Worms For Mayor
yea all zc blocks are j-spek engines. they're pretty easy to spot too. if you're farmiliar with all the dohc engines that honda has produced over the years this should be a gimme. here's a list of all zc block applications from the factory.
ZC Honda CRX (JDM) 1990-1993
ZC Honda CRX Si16/1.6i (JDM) 1989-1992
ZC Honda CRX Si (JDM) 1985-1987
ZC Acura Integra (JDM) 1990-1993
ZC Acura Integra (JDM) 1986-1989
ZC Honda Civic Si (JDM) 1986-1987
ZC Honda Civic Si (JDM) 1988-1991
good luck
Old Sep 8, 2004 | 12:29 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
the engine will look just like the D16A DOHC first generation Integra motor. the valvecover will look similar to the B18B LS. there will be a ZC stamp on the block.
Old Sep 18, 2004 | 08:34 AM
cashizslick's Avatar
cashizslick
:lol:
True That.
