Which B-series swap?
Old Aug 22, 2004 | 02:29 PM
slik civic's Avatar
slik civic
Default Which B-series swap?
I've got a '99 Civic EX, and want to do an engine swap, but can't decide which route to go. I've been considering a B18c1 and the B20 CRV engine with a V-tec head. The B20 looks to be a little cheaper, but I don't know how hard it will be to stuff under the hood. Either way, I'm going to use a mild turbo to try to get around 250-275hp. I'm not really sure if there are any other options, but if so, let's here about it!
Also, other than local salvage yards, where might I look for a good deal on an engine?
Old Aug 22, 2004 | 03:05 PM
Snoopy's Avatar
Snoopy
been there done that
how much do you have to spend?
Old Aug 22, 2004 | 03:08 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
try Hmotorsonline.com for your motor. They have a good rep.
I'd also like to know what your budget is on this. If you want a swap and a turbo, be ready to shell out around $5k at least...
Old Aug 23, 2004 | 06:22 PM
WhatNow's Avatar
WhatNow
n00b
i shouldnt really be giving this out but... if you're interested in some crated motors, blocks or goodies you might wanna check out http://www.importbuilders.com and if it's not your thing, you can actually have you're crated motor dialed in and tuned before you receive it at your doorstep...
Old Aug 26, 2004 | 04:18 PM
slik civic's Avatar
slik civic
I'de like to keep it under 7K.
Old Sep 18, 2004 | 08:36 AM
cashizslick's Avatar
cashizslick
Well, if you are planning to run boost, then just get a B18B and boost that. It will hold up better under presurization than the B20 will.
