No Spark... more complicated than normal!
Old Aug 9, 2004 | 11:45 AM
Running925's Avatar
Running925
Your Powder Coater
Default No Spark... more complicated than normal!
Hey guys i'm just lookin for some ideas on what else to check out..
B18A1 with no spark (engine cranks & turns over.. just no sparkage!)
Ignition Control Module is good
Distirbutor is good
Cap & Rotor are good
Starter Relay is good & grounded
Key switch is hooked up properly
Computer is connected
any ideas.. throw 'em out there at me
Old Aug 9, 2004 | 12:52 PM
powerflow's Avatar
powerflow
do you have any spark from the coil
Old Aug 9, 2004 | 01:20 PM
Running925's Avatar
Running925
Your Powder Coater
if i hard wire the coil to the battery & put a spark plug directly onto the coil yes. the coil is good.
Old Aug 9, 2004 | 02:05 PM
powerflow's Avatar
powerflow
did you check all the wires to make sure they are in the right ecu pins or other locations sounds like something is not hooked up right
Old Aug 10, 2004 | 07:11 AM
Running925's Avatar
Running925
Your Powder Coater
There are no pins that need changed.. i took EVERYTHING from the integra & put it in my civic body. Motor / ECU / internal & external wiring harnesses. (EVERYTHING)
Old Aug 11, 2004 | 07:33 AM
neex's Avatar
neex
Did you check the resistance of the primary and secondary windings in the coil? The coil *could* be bad even still. I just went through a bugger of a time with a no-start problem that took me two full days with the car on stands to solve. Guess what? I had Fuel, Air, Spark and Timing and it still didn't turn over. It ended up being an open on the tach sensing wire from the ICM. Make sure you check the ICM and coil religiously.
Also make sure you check the center carbon button and the spring from the coil that contacts the cap. I think you's still get a spark in the second scenario but you definitely won't start the engine.
Please let us know how you make out...
Andrew.
aka neex.
Old Aug 11, 2004 | 10:22 AM
Running925's Avatar
Running925
Your Powder Coater
thanks for the info neex.. i'll be checking over things again tonight. I was also givin a tip to check the crank sensor because it could possibly be bad & that would limit me from having spark.
My engine will turn over all day, it just won't spark. I've even replaced the ICM that tested good as well as my MSD distributor. I've put a stock distributor back on the engine so that it was using a stock coil (which tested good) also put a new cap & rotor on it. I just replaced the grounds that go from the chasie to the block with really nice ones.. just to see if that would help me out at all. I still get no spark.. this is extremly frustrating, i definatly appreciate all the help from everyone & i will keep you posted. thanks
Tony
Old Sep 5, 2004 | 10:19 PM
mickyhunt's Avatar
mickyhunt
Default What was the final outcome?
I have a civic ex 98 - stopped to get gas - turned engine off - when I tried to start the car it would not turn over - no spark as well - I am hoping it is just the coil.
Old Nov 9, 2005 | 12:58 PM
89CRXHF's Avatar
89CRXHF
Default Same problem, Different Solution???
Distirbutor is good
OK Dude heres my problem, Im doing a B18A1 swap into my 89
Old Nov 9, 2005 | 01:04 PM
89CRXHF's Avatar
89CRXHF
Default same problem, different soution??
[quote=89CRXHF]OK Dude heres my problem, Im doing a B18A1 swap into my 89 HF everything is hooked up, turning over , but no spark. I have also went through the check list that you did, and still nothin. I am starting to think outside the box and suspistion is looking tward timing. I am looking at my cam gears and the arrows are pointing at eachother, but as I look closer it looks like my timing is off half a tooth or so, I know that this could cause the engine not to start, and I am thinking it would also make it not spark. if you know any where to get a B18A1 Vacuum Diagram let me know, I need this
