ls vtec 1/4 q's
lol...
ok if the engine was running faster i think the 60ft would be better....
he has a good reaction time and he hardly skids out because he gets a good launch...MAYBE he needs to skid out more at the start but i dont think thats how it works? im newer to drag racing so....
has 15" rota slipstreams on falken drag radials...traction isnt the issue...its a stock honda clutch but i doubt that is hindering 1 sec in total time...
we think its the engine....WHY do people think THE ENGINE could be running so slow?
Originally Posted by DavE96GsR
lol...
If you've got enough power to burn through first gear, thats more than enough for a good 60'. Just practice your launch until you can get good traction without bogging or burning out. Also, if your camber isn't zeroed out, the tires (regardless of what kind) wont be able to grip to their full potential. Get an allignment and practice your launches... your problems are all in the 60'.
As for the engine... don't expect any improvements 'till you get it on the dyno... butt-dyno tuning and internet tips aren't gonna get you anywhere.
BTW, stock LS pistons still in there? If so your compression really isn't where its supposed to be to get the most out of those cams
:edit:also, what transmission are you using? That could make a huge difference.
gsr tranny, we have a b16a tranny that were going to try this weekend...
he is gettin good launches...he launches at the point were he is on the verge of burning out but doesnt...
im thinkin it has somthin to do with the sk2 ecu out of a built type-r b16a engine....because i figure it was all dialed in for the b16a which had all t-r components in it which could account for why this setup is running so shitty...
btw: im not thinking that by people posting 'internet tips' that its going to run better, i am only trying to figure out why this engine is running so damn slow....it should obvioulsy be running way quiker...mostly looking for a reason why it could be running so slow...
well an ecu program that isn't suited to your motor is a good place to start. I can guarantee you thats holding it back in some way.
Also perhaps the numbers you're considering to be typical are actually those of better motors (i.e., better pistons than ill-suited LS slugs). Like I said earlier, don't expect anything out of your itr cams until you've increased the compression and gotten a better tune.
