would you bother with a fancy headgasket?
Old Jun 9, 2004 | 12:18 PM
ISP James's Avatar
ISP James
DAMIMRED
Default would you bother with a fancy headgasket?
b18c5 bottom end, b16a1 top end
should i get a skunk2 spoon toda something like that headgasket or will the honda OEM be fine?
i am not changing anything else yet so the engine wont be under any abnormal force, i want to get some ITR cams later on this year but right now im just trying to get my engine together and in my car.
is there a diff. between b16a1 gasket and b18c5 gasket?
Old Jun 9, 2004 | 12:39 PM
1992CivicSI's Avatar
1992CivicSI
Don't Conform, Innovate
Most people recommend OEM gaskets unless you are under EXTREME condition...i.e. major boost.
Old Jun 9, 2004 | 03:09 PM
Kai's Avatar
Kai
Rotorphile.
Use a normal gasket.
Old Jun 9, 2004 | 03:30 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I used OEM on my first build and am using Cometic this time just because I want to be sure I get the right one for my bore size (84mm). I could go with a B20B gasket, but Cometic is just as costly. OEM handled ~300 whp and 14psi just fine.
Old Jun 9, 2004 | 05:49 PM
ISP James's Avatar
ISP James
DAMIMRED
yeah im going all motor so ill just roll with OEM.... which engine code?
Old Jun 9, 2004 | 07:01 PM
westcoaststyle
C5 if you're sticking with the stock C5 bore.
The head does not effect the gasket usage.
Old Jun 10, 2004 | 06:34 AM
ISP James's Avatar
ISP James
DAMIMRED
they are the same bore anyway, 81.5... jsut didnt know if one was thicker than the other thus affecting my c/r
Old Jun 10, 2004 | 10:06 AM
Eddiebx's Avatar
Eddiebx
yeah an oem gasket is fine, no need anything else
Old Jun 12, 2004 | 09:12 PM
honura's Avatar
honura
Seni
OEM ROCKs! hehe yeah oem will hold up good.
cvcsleeper
7
May 29, 2004 01:47 AM
flipped cracka
Dec 9, 2003 05:07 PM
CivOnDubs
Engine Swaps, Tech & Tuning
4
Jan 30, 2003 01:04 PM
LeftCorner
Oct 12, 2002 07:07 PM
gen2ls/vtec
5
Sep 11, 2002 06:55 AM
