Problem with O2 sensor and a/f ratio....
Old May 16, 2004 | 09:29 PM
taz77's Avatar
taz77
Originally Posted by sensei
If it was my car, I'd replace the primary O2 sensor. Sounds like the ECU is going into limp mode.
if you're running in limp mode, it'd be running rich, not lean...
if you snap the throttle real quick... does the gauge ever read rich?
Old May 17, 2004 | 02:55 AM
sensei's Avatar
sensei
with a bad O2, the gauge will show lean (low voltage signal) in limp mode even though obviously the car is running rich.
Old May 17, 2004 | 09:43 PM
taz77's Avatar
taz77
gotcha...makes sense
Old May 18, 2004 | 12:43 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
From my understanding of how the Honda ECU works, it has to be throwing a code to go into limp mode. A bad oxygen sensor doesn't always cause the ECU to throw a code, and if that's the case then the ECU doesn't go into limp mode. Limp mode is a function of the ECU, not of the oxygen sensor itself.
4wdcivic
Engine Swaps, Tech & Tuning
9
May 15, 2003 01:58 PM
undrgrndhaqer
10
May 14, 2003 07:14 PM
jaxrunner
May 4, 2003 12:48 PM
AadosX
Accord
11
Mar 14, 2003 09:53 AM
aut0tek
23
Sep 10, 2002 07:23 AM
