My Vigor just died...
Old May 26, 2004 | 08:42 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
If your check engine light is on and you take the car to a dealer, that is exactly what they do. Once they have the code, the shop manual has troubleshooting flowcharts for that particular code.
If you don't have a check engine light then the process isn't quite as simple.
Old May 29, 2004 | 06:27 AM
Kabuki's Avatar
Kabuki
I'm going to have to agree... Sounds like the Igniter or the Coil. Neither of them are in the distributor on the Vigor/2.5TL. It just has the cap, rotor and a couple of sensors.
Old Jun 6, 2004 | 07:54 PM
AcuraFanatic's Avatar
AcuraFanatic
To confirm the Vigor does indeed have an EGR valve.
Old Jun 10, 2004 | 09:07 PM
92vigor1's Avatar
92vigor1
The honda dealership tried to replace the M.A.P. Sensor, but that did not fix it.
Do you still think Ignitor? Its been tested, and its getting spark, but I dont know if its been tested right after/during it dies.
What about the computer?
Thanks for the helP!!
Old Jun 11, 2004 | 10:54 AM
92vigor1's Avatar
92vigor1
Ok, so the ignitor has been tested while its dead, and its getting spark.
It got the error code 3 and they tried the MAP sensor, nothing... Now they want to replace the crank angle sensor.
What do u thinK?
Old Jun 27, 2004 | 05:25 PM
AcuraFanatic
I'd try the crack angle sensor.
If that doesn't work, I'd look into a bad ECU.
Old Jun 27, 2004 | 07:45 PM
92vigor1's Avatar
92vigor1
Since my last reply to this thread, its been fixed.
The seals where worn away in the camshaft, and oil was gushing into the distributer.
Mike Oxbigger
Apr 17, 2004 02:27 PM
SaviouR
Dec 26, 2003 10:08 AM
horoke14
CRX & Pre 92 Civic
2
Nov 24, 2003 05:13 PM
95EXSDN
Sep 17, 2003 08:58 PM
pSiRacer92
Apr 1, 2003 03:52 PM
