will a automatic OBD2 ECU work on a 5speed b16a2
Old Apr 18, 2004 | 05:43 PM
teg92's Avatar
teg92
WHAT OK YEAH!
Default will a automatic OBD2 ECU work on a 5speed b16a2
I have a 1998 honda civic dx and Im putting a b16a2 I have a OBD2 automatic ECU but the transmission is 5speed will the automatic ECU work on a manual transmission
any help would be good
thank you
Old Apr 18, 2004 | 10:13 PM
matr1xhawj's Avatar
matr1xhawj
thank you
it should work. My brother's auto ecu p28 worked on a manual p28.
Old Apr 18, 2004 | 10:38 PM
madxmanx's Avatar
madxmanx
This might help you out. http://www.torontocivics.com/article...to-manual.html
Old Apr 19, 2004 | 09:10 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Your car is going to run like crap! For one thing, you'll forever have a check engine light because the ECU will assume the automatic tranny is just failing to respond. Also, I'm not away of any DOHC VTEC ECU's that are automatics and would plug into an OBD II ECU plug so I'm guessing your planning to reuse your DX's ECU. Not only will that ECU not have the VTEC activation point or VTEC fuel maps (you'll be stuck on the small cam the whole time), it will probably hit a revlimiter at least 1000-1500 rpm before the B16A is ready. I don't believe it will damage the engine in anyway, but it will handicap it to such a point, the whole swap was probably pointless.
Old Apr 19, 2004 | 10:03 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Can I use my ECU and just run the vtec wire?? Or that wouldnt work either?
Old Apr 19, 2004 | 10:23 AM
Andy's Avatar
Andy
Run a VTEC wire to where? You could buy an RPM activated switch and make it work to tell the engine to swtich to the big cams at the right time (or a VTEC controller like a V-AFC) but you still have the other issues. For one thing, the fuel maps are all wrong for the engine anyway, and worse, you'll be using the VTEC cams without the VTEC fuel maps. The big side of a set of VTEC cams can ingest more air than any normal street cam could, by matching that with the proper fuel ratio, that's where a VTEC engine gets it's extra power. If you don't have those fuel maps, your ECU will continue to feed it the lower fuel amount than it needs. This will run the engine lean, which may net you some power gains but it can also be very dangerous as a lean engine runs hotter. Your risk detonation and maybe throwing a rod out of the block. A V-AFC could potentially compensate by raising the fuel once you hit the VTEC point, but without a dyno and wideband O2 sensor to tune it, your just basically swinging in the dark. This is ignoring the fact that an automatic non-VTEC D-series ECU will cut the engine short around 1500 rpm short of it's redline, basically slicing off the hightest part of the engine's powerband. You need the right ECU for your engine.
Old Jul 19, 2004 | 12:28 PM
seks727's Avatar
seks727
Here you go.
Tr0LL
Engine Swaps, Tech & Tuning
Mar 21, 2003 09:34 AM
Tr0LL
Mar 10, 2003 12:12 PM
Stage5Lude
Mar 10, 2003 11:27 AM
MoFo
92+ Civic/EL & Del Sol
6
Feb 19, 2003 05:59 PM
loodboi
7
Feb 14, 2003 07:43 PM
