how to change the valve springs?
Old Apr 15, 2004 | 01:57 AM
jp184's Avatar
jp184
Default how to change the valve springs?
Can I change the valve springs on B16A without dismounting the cylinder head and while leaving them by the top under the camshafts?
Smone body has the honda installation diagram for that ?
Thanks
Jp184@hotmail.com
Old Apr 15, 2004 | 04:38 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I'd have to say no. You have to pull the valves out from the bottom so you'd have to take it off the block. h:
Old Apr 16, 2004 | 02:12 AM
jp184's Avatar
jp184
Houps!
That just to change the springs, somebody knows where I can find the installation diagram?
Old Apr 16, 2004 | 05:32 AM
shivers's Avatar
shivers
Moderator Alumni
This should give you a better idea of what's involved.
http://www.c-speedracing.com/howto/caminstall/cam.php
2005 s2000
Old Apr 17, 2004 | 05:33 AM
jp184's Avatar
jp184
I find that but i haven't all
Old Apr 17, 2004 | 04:07 PM
TheRooster's Avatar
TheRooster
Former Senior Member
You can do it with the head on the car. You get an air fitting with threads that match your spark plug. Pressurize the cylinder to prevent the valve from falling (hope that your valves have a good seal. If they don't, then losing the valve in the cylinder and pulling the head is a good thing. You'll want to lap the valves anyways.) There is a setup (and the helm's manual doesn't show it, but if you do some searching around the net you can probably find it) that consists of a long bar that runs the length of the head. It bolts to the head and you use a lever that hooks under the bar and sits down on top of your valve spring retainer to compress the spring. Then it's a simple matter to put the keepers in place.
Taking the head off is easier, but you're going to have to order/fabricate some special tools to work with a standard valve spring compressor clamp. I used some square stock with keyways cut into it.
98CoupeV6
News & Rumors Archives
24
Jan 7, 2004 09:25 PM
cranberynvodka
Sep 28, 2003 06:51 PM
Jessica
Sep 4, 2003 07:59 PM
98CoupeV6
30
Apr 1, 2003 02:33 PM
kazi
17
Jan 6, 2003 02:18 PM
