cold air intake
Old Mar 18, 2004 | 06:23 PM
Darin's Avatar
Darin
Default cold air intake
I have a 98 Honda Accord. With V-6 Vetc.just put on cold air intake.wondering is there anything.that I need to do after I install this.or do I just put on and drive. Just kind of worried engine seems to make more noise now.just wanted to make sure not going to screw something up
Old Mar 19, 2004 | 10:32 AM
Civic Type Sev's Avatar
Civic Type Sev
Making more noise is the beauty of it! It's normal.
The only thing that I recommend if you havent done so already after the install is to reset the ecu. You can simply disconnect the battery, wait a few seconds and then reconnect it. Your ecu will be able to adjust to the new setup.
Old Mar 19, 2004 | 10:50 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The preferred method of resetting the ECU involves pulling the fuse in the underhood fuse box marked BACK UP for 15 seconds and then replacing it.
The absolute best way to do it is while the car is cold, turn the key to the on position so you can turn off all of your accessories (stereo, ventilation, etc). Then turn the key off and pull the fuse. After you put the fuse back in, start the car up and let it idle until it comes up to temp, being careful not to turn on any accessories or step on any pedals.
Old Mar 19, 2004 | 12:44 PM
96GreenCivic's Avatar
96GreenCivic
I never reset my ecu when I installed my SRI. Do you think that is making any difference? But the noise is part of the mod. I like the extra noise I get.
Old Mar 19, 2004 | 05:37 PM
Darin's Avatar
Darin
THanks for the info.thats good about the noise.becouse i like it to.I will reset my ECU and call it good. thanks again.
Old Mar 19, 2004 | 06:24 PM
93Nteg's Avatar
93Nteg
if you wanna be cautios put a bypass valve on it so you don't suck up an ass load of water when your driving in bad weather conditions with big puddles.
Old Mar 19, 2004 | 11:20 PM
dustimus's Avatar
dustimus
Better golfer than you
No, after a few days your ECU will slowly adjust itself, it just makes more sense to do it when you first install.
Black '98 Civic
92+ Civic/EL & Del Sol
58
Jul 23, 2003 08:10 PM
ToddnMiss
Engine Swaps, Tech & Tuning
Jul 5, 2003 07:09 PM
Mugenboyz
2
Mar 15, 2003 05:24 PM
ls-r
Dec 17, 2002 04:58 PM
