Code #9 need help please
Old Aug 2, 2002 | 08:27 AM
LadyCivic96's Avatar
LadyCivic96
Default Code #9 need help please
Ok... Need help ASAP. We recently put a D16Z6 into a '91 hatch. The swap itself went smoothly until startup. At startup we are knowing getting a MIL/CEL Code #9 (#1 cylinder position defective circuit or unplugged/defective sensor). Knowing that the sensor is in the distributor, we started there. We tested it and found that it was bad. So we went and bought a new (remanufactured) distributor. We put the new one on and we are still getting the code. We have check and double-checked the timing and it is dead on. We are running out of ideas on what to check or change. Any ideas?
Old Aug 2, 2002 | 09:09 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Are you running thr right ECU/ECM?
Old Aug 2, 2002 | 09:18 AM
red GS-R's Avatar
red GS-R
shhhh...just be quiet.
I'm having the exact same problem in my 92 GS-R. I've replaced the whole distributor housing about 3-4 times.
We're going to replace it one last time today, reset the ECU properly, and I think I'm going to buy a new cap also. I really have no clue on how to fix it, I've tried replacing it a million times. We've timed it, did a full tune-up, replaced rotor,cap, plugs, wires. Nobody I've talked to knows what to do, even though a few people have had the same problem.
Some guy I talked to said it was the crank angle sensor in the distributor. It made his car idle REALLY low and his car cutoff at 3-4k RPMs, instead of going to the redline. I've had that same problem with one of my distributors. With the one I have on now, the check engine light is on, it idles low, but I can take it all the way up through 8000 RPMS. He says its the crank angle sensor that makes your car idle low, and he replaced his by taking two distributor housings, and taking the parts out of both to make one good one.
Old Aug 2, 2002 | 12:31 PM
LadyCivic96
We re-ran the wires from the ECU to the distributor and the code it now go. The pins were right but there must have been a break in the wire or a wire crossed somewhere.
Old Jul 17, 2003 | 11:18 PM
ek97hatch's Avatar
ek97hatch
Hey, the other distributor he used to swap out the parts, was it the same obd version gsr dist. also? I'm having the same problem. My car wont go pass 3500 checked my ecu and it threw the code #4 which is the crankshaft position sensor.
redcivicforever
CRX & Pre 92 Civic
11
Aug 11, 2006 02:26 PM
SwifT
Aug 3, 2004 03:25 AM
IGOTTOGETFREE
Accord
3
Mar 11, 2003 09:55 AM
