Bore size effect on L
Old Mar 12, 2004 | 11:12 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default Bore size effect on L
Ok, I'm looking at getting sleeves and boring.. all that jazz.
I could either get a 81.5mm piston or a 84mm piston.
If I have a 1.8, what will getting an 84mm bore do to that figure?
What are your thoughts between 81.5mm and 84mm?
Thanks!
Old Mar 12, 2004 | 11:52 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Displacement is
Pi*r^2 * stroke * # cylinders
so if you're starting out on a 1.8, an 84mm piston will put you just under 2.0L, but close enough to call it 2.0L
-Harry
AIM: NDcissive
Old Mar 12, 2004 | 11:53 AM
shivers's Avatar
shivers
Moderator Alumni
In just doing some quick calculations (assuming you're staring with 1797cc), a piston 81.25mm will bring you up to 1808cc and a 84mm piston will get you up to 1933cc.
Essentially you'll have a 1.9L with 84mm pistons. You'll also get some added tq from the increased displacement. Any idea what compression you'll be shooting for? Extra compression will also give you some more power across the board.
I'm sure there's other people on the board that can give you more detailed info than this, but at least it's a starting point. Keep in mind that the 81.25 pistons can go in with minimal work, while the 84mm will probably require a resleeve.
EDIT: I forgot you're boosted. My reply is presented from an N/A perspective ... I always forget about you crazy F/I guys.
2005 s2000
Old Mar 12, 2004 | 11:57 AM
1stGenCRXer
Is the engine a B18C or B18a/b?
A 2.0L boosted LS can be quite robust and fast
-Harry
AIM: NDcissive
Old Mar 12, 2004 | 12:52 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Hahaha it's never enough, is it?!
If you're going to sleeve the motor you might as well punch it out to 84 mm bore while you're in there.
Old Mar 12, 2004 | 01:09 PM
westcoaststyle
Going with AEBS for sure. Putting in custom AEBS/Someone else 9.5:1 pistons and I have the option of either 81.5 or 84, that's why I'm asking.
Going to get it o-ringed too. :naughty:
No, IT'S NEVER ENOUGH!!! *Dr. Evil laugh* :chuckles:
:edit: B18C1
:edit2: would you recommend an 84mm on a daily driver? I currently have a GSR radiator and FAL fan - FYI.
Old Mar 12, 2004 | 01:18 PM
qtiger's Avatar
qtiger
84 mm is the FI standard for resleeved motors. Shouldn't be an issue. I know some people go farther than that on NA motors.
81.5 would be for keeping stock bore... probably just for classing reasons.
Old Mar 12, 2004 | 01:20 PM
westcoaststyle
h:
84 it is then.
Pharmacist
CRX & Pre 92 Civic
5
Feb 19, 2004 07:21 AM
FLip wit da Flo
Accord
8
Feb 7, 2004 08:33 AM
Snoopy
Engine Swaps, Tech & Tuning
4
Dec 30, 2002 10:36 PM
91AccordCoupe
Accord
10
Dec 21, 2002 11:36 AM
maxrpm
3
Nov 7, 2002 03:40 PM
