Vibration at idle 97 2.5tl
Old Mar 9, 2004 | 05:55 AM
steve 97tl's Avatar
steve 97tl
Default Vibration at idle 97 2.5tl
Ive done a full tune-up plugs,wires,cap,rotor,pcv valve,fuel filter, cleaned throttle body, air filter, cleaned egr valve cleaned(ports into engine). Im out of thoughts. no cel's no codes stored had vales adjusted . I checked resistance and coninuity on the coil and some values were out and some didnt even show a value followed serv manual to check it. Any suggestions please advise. Also replaced left front engine mount and tranny mount.
Old Mar 9, 2004 | 06:16 AM
StreetProwler's Avatar
StreetProwler
I'm not very familiar with the 2.5TL engine, but does it have balancer shafts (like the Accord 2.2L/2.3L)? If so, they need to be "timed" to the crankshaft just like the camshaft is. They have their own little timing belt! If this applies to your engine, make sure that the balancer shafts haven't skipped teeth. I'm assuming here that you have vibration at different engine speeds, along with idle.
Old Mar 9, 2004 | 07:57 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
if its a really bad vibration check ignition stuff.
Old Mar 12, 2004 | 05:24 AM
steve 97tl's Avatar
steve 97tl
2.5 5cyl has no balancer belt all ignition parts new
Old Mar 12, 2004 | 09:15 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Well, given that you're getting some funky readings from the ignition coil I'd say that's the most likely source of your problem.
Vader1
Accord
25
May 1, 2004 11:39 AM
steve 97tl
CL, TL, TLX & Vigor
10
Apr 14, 2004 02:15 PM
Vader1
Engine Swaps, Tech & Tuning
6
May 13, 2003 06:05 AM
preylude99
6
Feb 16, 2003 02:22 PM
preylude99
7
Jan 18, 2003 11:11 AM
