30 Seconds of Joy - H22 / f22 Electrical Problem
Old Mar 1, 2004 | 04:43 PM
93R33Lude's Avatar
93R33Lude
Default 30 Seconds of Joy - H22 / f22 Electrical Problem
Hi
Just finished hard part of f22 to H22a in 93 Prelude swap. Added the necessary wires (VPS, VSV, KS, IAB) to H22 ecu using F22 harness with mods and extensions. Coil that came with Osaka engine is internal - F22 was external. On forum advise, splice coil connector black/yellow to yellow.
Engine started on third crank. Ran Great! Turned off, Tried to restart but would not. No spare from distributor.
Voltage checks at distributer with ignition on - power on all wires except Yellow/Green.
No Check engine MIL light. Installed jumper connector to diagnostic plug. Check Engine (MIL) stays on. No fault codes. Removed jumper turned on ignition and disconnectected EGR, MAP sensors - No check engine light until I removed TP sensor.
All fuses good, all grounds good. Performed ECU diagonstic procedures as outlined in Chilton / helms.... "Made it down to replace with known good ECU and try to start..."
Any suggestions anyone?
Old Mar 1, 2004 | 05:07 PM
qtiger's Avatar
qtiger
Check your grounding straps.
Old Mar 1, 2004 | 05:42 PM
ludeboom's Avatar
ludeboom
make sure your fuel injectors are grounded via the thermostat housing
does it run on ether?
u said no spark, check the rotor in distributor, otherwise distributor may be shot all together (ive seen it before on internal coil JDM distributors that have been sitting for god knows how long)
~boom
Old Mar 1, 2004 | 06:11 PM
93R33Lude's Avatar
93R33Lude
Yep, got grounds, new rotor, distributor... Is the black/yellow to yellow splice a valid modification for external coil F22 to Internal H22 distributor valid? Odd it ran at all, but hey the distributor probable sat around for a long time - had a crack cap due to shipping, Heck could have been the hanger queen distributor....
secksiman19
Accord
Feb 28, 2004 09:29 PM
alpine
Accord
3
Jan 30, 2004 05:09 PM
djmtsu
Accord
22
Aug 29, 2003 09:09 PM
ambition
Aug 7, 2003 11:46 PM
The Dude
Aug 10, 2002 08:09 AM
