Fluidyne is it worth it
Old Aug 19, 2002 | 11:08 PM
TurboTegGSR's Avatar
TurboTegGSR
I have a 95 gsr with a drag 2 turbo kit and bought a fluidyne with the f.a.l. fans and found out it didnt fit. So i cut the fan shroud in half and am only running the passenger side fan. I also removed the a.c. condensor and the lines. Car runs cool and the fan rarely turns on in less than 80 degree weather unless i have been idling for 5 to 10 minutes. Oh yeah I later found out that if you have this setup you are suppposed to get a civic fan which is half a gsr fan set. :doh: F.A.L should mention this without having to half to call them. If I was you I would get the fluidyne and a civic fan or you could get the integra fans and cut them in half and be super cool!!!:ghey:
Old Aug 19, 2002 | 11:55 PM
HybridTegra's Avatar
HybridTegra
Well i was gonna get a fluidyne cause my stock radiator got a hole in it so i figured since i gotta replace it why not upgrade it too....Well i ended up just gettin the fluidyne and removin the A/C with my teg fans...everythings is cool.....thanks fools for all the advice.....
Old Aug 20, 2002 | 12:53 AM
dubcac's Avatar
dubcac
I
Check out PWR radiators. They use stock fans, and all stock mounts, very clean setup.
jwaked
Engine Swaps, Tech & Tuning
6
Mar 6, 2006 07:57 PM
Blizzard
7
Oct 21, 2002 04:59 PM
contraption22
2
Aug 30, 2002 07:23 PM
confucius
Aug 21, 2002 09:14 AM
nonbox
10
Jul 30, 2002 04:53 PM
