What does "Adaptive Transmission" mean?
Old Feb 10, 2004 | 09:33 AM
Geckoboy's Avatar
Geckoboy
Default What does "Adaptive Transmission" mean?
I see the following term a lot:
"5-Speed Sequential SportShift(TM) Adaptive Manually Interactive Automatic Transmission With Overdrive"
Specifically, on the Acura TL's
What does that mean? Does anyone have a link with more information? I could not find any more details on it.
Thanks,
Chris
Old Feb 10, 2004 | 11:42 AM
Kestrel's Avatar
Kestrel
Push to shock!
Sounds like to me that it's a fancy way of saying 5-speed automatic with manual sequential shifting mode. The adaptive part I would imagine is an electronic module that adjusts shift points with "driving style."
Old Feb 11, 2004 | 12:37 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
yeah so if u mash the pedal allot it will learn and shift higher towards redline
if ur grandma drives then it would shift at 2500rpms and be in fourth at 35mph all the time
Old Feb 12, 2004 | 01:11 PM
Geckoboy's Avatar
Geckoboy
Default Interesting..
interesting.. so how would you reset it to start learning your driving style all over again?
Old Feb 14, 2004 | 12:32 AM
Kestrel's Avatar
Kestrel
Push to shock!
Don't know really. I suppose disconnecting your battery might do it.
Old Feb 14, 2004 | 12:59 PM
Prince's Avatar
Prince
No depending on how you race u r put into one of specific profile and car behaves accordingly....for example, if u push the pedal to the metal, car will change gears at redline, but if u just pushing it slowly then gears will change at 3rpm or before....
Old Feb 14, 2004 | 04:06 PM
DakarM's Avatar
DakarM
to reset it just drive is more aggressively. that worked with the 330i.
i used to slap it into the manual gear change mode (that puts it into sports mode) the shift would hold til redline and also downshift when braking and holds the gear so you can acclerate out of turns.
now i don't need to do it since I've started to drive a little more aggressively in the "auto" mode. the upshift are done at near or at redline depending on the throttle position, etc.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
