Knock sensor question - Any Ideas
Old Jan 5, 2004 | 09:03 AM
latin_racer's Avatar
latin_racer
Default Knock sensor question - Any Ideas
91 Integra GS
I bought a b16 swap from a guy who had it installed already on his integra. So I got the engine with the harness already installed.
When I look at the knock sensor behind the engine by the oil filter I found out that it's connected to a plug on the harness.
I searched and find out that the knock sensor should go to the ecu. So why is it connected to the harness?
Should I just unplug it, and wire the knock sensor to the ecu. Will it cause anything since I removed it from the harness? Then where does this plug go to then?
Any ideas appreciated....
I will get some pictures later, and I notice that the plug has 2 wires going to the harness instead of one.
Thanks,
Old Jan 5, 2004 | 09:15 AM
27Sec-Type-R's Avatar
27Sec-Type-R
What Ecu are you using?
Try this one http://tech.hybridgarage.com/tech/info.html
Old Jan 5, 2004 | 09:16 AM
latin_racer
PWO - The guy said it has MUGEN CHIP-- But I dont know if it's true.
Old Jan 5, 2004 | 09:21 AM
27Sec-Type-R
*Btw can u list the year of the engine and comp? (if you know)
Old Jan 5, 2004 | 09:27 AM
latin_racer
First Generation B16a From Honda Civic SI.
The ecu is: 37820-PWO
Old Jan 5, 2004 | 10:30 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Where do you think all the wires on your engine harness connect to?
-PHiZ
