Lack of POWER on B20-R
Old Jan 2, 2004 | 03:19 PM
27Sec-Type-R's Avatar
27Sec-Type-R
Ok, Im connecting the Vtec here shortly.
I just thought even though the Vtec was disconnected, the motor would be stronger then a Geo metro w/5 passangers
I'll let u Know how it goes,
Thanks
Old Jan 2, 2004 | 09:59 PM
27Sec-Type-R
All Right, Problems not over yet, I wired up the Vtec and test drove it, Everything is the same, but when Vtec engages it pulses (like a redline limiter) Maybe restricted airflow?
**btw Im using an Ls throttle body right now, could this restrict air that much?
Old Jan 2, 2004 | 10:00 PM
Kai's Avatar
Kai
Rotorphile.
That throttle body isn't restricting anything.
Old Jan 2, 2004 | 10:16 PM
27Sec-Type-R
Could the tps sensor be damaged?
Old Jan 3, 2004 | 04:35 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
any CEL's coming up?
Old Jan 3, 2004 | 06:34 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Take this one to a shop, man... it sounds bad.
Old Jan 3, 2004 | 08:01 PM
qtiger's Avatar
qtiger
I'd suggest upgrading that ECU or even temporarily using a stock ECU to find out if it's throwing codes.
Old Jan 4, 2004 | 01:38 AM
tungsten2k's Avatar
tungsten2k
Old Jan 4, 2004 | 08:59 AM
qtiger's Avatar
qtiger
Originally posted by tungsten2k
a stock ECU will not get you any better as the flow requirements for each engine are so different that if there *isnt'* anything wrong with his current ECU then using a stock ECU will only exacerbate the problem. Bottom line, fuel and timing maps for a stock 1.8L won't run a 12.5:1 2.0L with a bunch of mods very well without some serious tweaking.
btw- thank whoever deleted my post which was directly above yours, which pretty much said, in not so many words, what i was refering too above.
A stock ECU will throw CELs. A Skunk2 chipped ECU will not throw codes. It ignores them.
Old Jan 4, 2004 | 09:31 AM
tungsten2k's Avatar
tungsten2k
Ok I could try another Ecu, a little hard to get 1 right now.
I also noticed that my fuel is running extremely rich, soaking the spark plugs.
I also have a si throttle body on the way, switching my o2 sensor (from stock ls 1, probably never changed), will be doing a fuel pressure and oil pressure test after the throttle body comes.
On another note, My rpm on my cluster is innop., Isn't the blue wire on the dizzy run to the rpm? (*swapped 0b1ls dizzy w/ obd2 type r dizzy).
Some notes on this would really help.
Thanks
i think you need more help than anybody here can give you.
good luck !
