Outer CV Boots
Old Nov 26, 2003 | 06:01 PM
firebane's Avatar
firebane
Default Outer CV Boots
1993 honda civic... Anyone know how to replace the outer cv boots on these cars? Do you need to use a split boot? I'm confused and can't figure it out.
It seems that in order to replace one you have to replace both or am I mistaken on this? And if that is so I don't have the money to replace the inner ones at this moment, so do you think it would be possible to cut the new ones to make a split boot and stick it on this way?
Old Nov 26, 2003 | 07:41 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
You need to take the axles off the car and take the inner joints apart to slide the boots off the shaft. You can re-use the inner boots if you want to (check for any cracks or tears in the rubber). It's a very messy job. If the axles have started to click, replace them. The split boots you can buy don't work too well. Splitting a boot yourself will probably never work.
Old Nov 27, 2003 | 08:27 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
From what I understand the boots cost just about as much as axle replacements do.
NAPA sells replacements for ~$60/ea + core and they have a no questions asked lifetime replacement on them. It's so much easier to replace the entire axle than it is to replace boots.. imo.
hih
Old Nov 28, 2003 | 01:54 AM
Gasoline Fumes
If you're paying for the labor, the cost will be about the same. Two axles for $120 is a bit more than the boots. The boots shouldn't be more than about $12 each.
