Custom Turbo Help
Old Nov 24, 2003 | 11:09 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default Custom Turbo Help
Working on a fully built CRVTEC here.
It's got a 99 Si/SiR B16A head with valve springs, ss valves, crower stage 2 turbo cams, skunk2 cam gears, skunk2 intake mani, arp head bolts, port and polished and a 5 angle valve job.
Block is a B20, sleeved with Golden Eagles Godzilla sleeves, eagle rods with arp rod bolts and JE pistons sporting a 9.5:1 CR. Car will be tuned with AEM EMS.
This thing will take some serious power so I'm wondering what kind turbo, manifold and fuel stuff I should run?
Old Nov 24, 2003 | 11:53 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
What are you going to be reving to?
I'd go with a sc61 from precision and an Full Race equal length manifold.
Old Nov 25, 2003 | 08:08 AM
The G2 Racer
Want Boost!
Most likely a rev limit of 8500-8600 just to be safe. I'm sure it could rev to 9000 but I don't want to push it.
I was thinking of the Full Race equal length manifold. I'll look into that turbo.
What about fuel?
Old Nov 25, 2003 | 11:17 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
At least some 780's injectors, aem fuel rail, walbro 255lph in tank, and some hondata s200 to tune it all.
Old Nov 25, 2003 | 12:51 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:werd:
780s? Dayum!
Why so much?
Old Nov 25, 2003 | 12:54 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
They leave a lot of room for turning up the boost. With a motor built that way you need to run high boost to get the most out of the setup and the turbo. Anything lower is just uncivilized.
Old Nov 25, 2003 | 12:58 PM
westcoaststyle
Get one of these.... they're so FOCKIN' cool!!!
www.forcedperformance.net
Old Nov 25, 2003 | 01:08 PM
The G2 Racer
Want Boost!
Thanks for the info txhatch.
I'm going to run the AEM EMS as far as engine tuning is concerned however.
Westcoaststyle: I'm gonna check that link.
Old Nov 25, 2003 | 01:13 PM
westcoaststyle
You should hear that thing... I nearly had to change my pants when I heard it on a Supra...
The link for the vid's down right now.. I'll try to make a new one.. one sec
Check it!!!
Old Nov 25, 2003 | 01:14 PM
The G2 Racer
Want Boost!
ok.
