Wiring in VTEC to a 92 cx w/d15b
Old Nov 16, 2003 | 03:28 PM
DRTHV8R's Avatar
DRTHV8R
Default Wiring in VTEC to a 92 cx w/d15b
I have the p28 computer, and want to hook up the vtec. Does anyone have pics or a diagram of which pins on the ecu I need to hook into? I've heard of re-pinning os something like that. Is that how you tap into the correct pins? Any info would be great.
Old Nov 16, 2003 | 04:47 PM
Kai's Avatar
Kai
Rotorphile.
Actually, all '92 model hatchbacks are supposedly prewired for VTEC. Is yours not?
Old Nov 17, 2003 | 06:24 AM
DRTHV8R's Avatar
DRTHV8R
Its not. There was no pin in the d6 portion of the ecu. I wonder if it is because the car is for Canada?
Old Jun 3, 2005 | 09:26 PM
noturavgsyco's Avatar
noturavgsyco
I just looked up this tread and i am having the same kind of trouble. there is no pin for d6 and it says that the knock sensor is suppose to go there for vtec. do I just pull it out of the other slot and stick it into d6? so confused , if anybody can help I really would like it. thanks marc
Old Jun 3, 2005 | 09:34 PM
b16ahybrid's Avatar
b16ahybrid
that motor and that ecu (p-28) doesn't run a knock sensor.
Your cabin harness should have all the wires already for vtec, you just need to run the wires to the plug by the firewall from the engine.
run to ecu pin
A4 vtec solenoid
A20 evap purge
A17 iab
and
D6 vtec pressure switch
that should be all for you to run.
Old Jun 4, 2005 | 10:36 AM
noturavgsyco
so i just run it striaght to the ecu? b/c I already ran d6 and a4 straight to the ecu.
Old Jun 4, 2005 | 12:35 PM
b16ahybrid's Avatar
b16ahybrid
You can, but the wires should already be there in the engine bay.
Old Jun 4, 2005 | 10:33 PM
noturavgsyco
I don't have a pin for the a17? so how do I run that to the ecu?
Old Jun 5, 2005 | 09:21 AM
dslammed93's Avatar
dslammed93
slammed93
im confused do you have the vtec wiring harness?? or are you just splicing some wires from the solenoid to your p28 ecu? for it to run... cause i bought a vtec wiring harness(hooks up to the vtec solenoid then it goes through the firewall to the p28 ecu) for about 100 bucks from a local shop here in texas) i went from a non vtec to a vtec in my 93 civic so what intake manifold do you have on your y8 cause i have my stock d15b7 intake manifold on my y8....let me know
Old Jun 5, 2005 | 07:37 PM
noturavgsyco
I got a d16z6 intake mani and nah I didn't splice anything but I don't a pin for a17 so how do I run that one
