What to do to get 12's?
Originally posted by SadisticRacing
I plan on doing a full build of this motor top and bottom ends just was trying to get suggestions on what could get me there by next year.
First, I need to know exactly what your mods are. Some will need to be replaced I'm sure.
Not stage 1: Skunk2 stage 1 cams, Skunk2 valvetrain. Hondata.
Not stage 2: Stage 1 + CTR pistons, Eagle or Crower Econobillet rods. Hondata.
All out stage 1: B18C1 block or GE sleeve to 1.8 liters, CTR pistons (if GE sleeve then 12:1 CR forged pistons), Crower Econobillet rods, Skunk2 stage 2 cams, Skunk2 valvetrain. Entire exhaust system should be at the least 60mm, preferably 2.5." Hondata.
All out stage 2: B18C1 shortblock and sleeve to 2.0 liters, 12:1 CR forged pistons, Crower Econobillet rods, Skunk2 stage 2 shizot, 2.5" exhaust. Hondata.
The first "stage" might get you to 12s with light rims, good tires, and a nice launch. Anything else should definately get you 12s.
The only mods to my engine our STR cam gears, STR fuel rail, STR 68mm TB, intake manifold, AEM CAI, DCSports Header, custom 2.5" exhaust with STR tip, no cat, and B&M FPR w/gauge plus the 75-shot dry nitrous Zex system.
Well since STR gave me a partial sponsorship that's why and I plan on getting cams this winter and the fuel rail is doing something because we had to up my fuel pressure due to the TB, intake manifold, and intake. There was to much air and not enough fuel.
If your not going to help then shut up please!!!
i'd say the fastest way to get there is turbo... not a turbo KIT that you can get for $2000 + for the b16 but a junkyard turbo set up.... www.homemadeturbo.com they will really help you out there. i'd say a T3 turbo external wastegated, get new pistons and a new cam, valve and valve springs and you shoudl be able to push probably with tunning.. safely at LEAST 12 psi. you will def. be in the 12's with slicks then... probably low 12's. just my .02!
