HKS Turbo Timer problem
Old Oct 16, 2003 | 10:11 AM
joebenz's Avatar
joebenz
nelson rules
Default HKS Turbo Timer problem
yo.. check it:
TT is working... but when take the key out the car.. it sort of stutters a bit, and tries to shut off... but then the TT kicks in and stops it. I've spoken to other fools on the boards, and their TT's are completely seamess. when they shut it off, you cant even tell you took the key out.. its just a smooth transition. argh!! i'm going to check the parking brake splice to make sure its clean. any other ideas?
no sig
Old Oct 16, 2003 | 07:22 PM
TurboedF22A's Avatar
TurboedF22A
the only thing that i can think of is to double check all your connections and make sure that your tapped into the right ingnition wires. also, the parking brake shouldnt have anything to do with that, its just a safty option.
Old Oct 18, 2003 | 05:44 PM
joebenz's Avatar
joebenz
nelson rules
hmm...well we did use the harnass, so ignition wires was pretty much plug n play. do you think the ground would have anything to do with it?
no sig
Old Oct 18, 2003 | 10:20 PM
TurboedF22A
Yeah, its possible that a bad ground could cause problems. The only thing I can say about that is to make sure that there is a really good metal-metal contact. Otherwise, you might have a faulty timer cause if everything is hooked up correctly, there shouldnt be any problems.
Old Nov 8, 2003 | 06:26 AM
boostlee's Avatar
boostlee
yeah bad good possibly
maybe check you battery to make sure it is kicking out enough voltage. also your alternator??
could be something with you charging system giving that stutter
you idle is within range right???
Boost Lee
