turbo install?
Old Oct 15, 2003 | 10:39 AM
lookin4rice's Avatar
lookin4rice
Default turbo install?
if i buy a garrett t25/t28 turbo what else will i need and does it also mean i have to sacrifice my ac?
Old Oct 15, 2003 | 05:40 PM
Snoopy's Avatar
Snoopy
been there done that
are you getting just the turbo? if so, you'll need a manifold, all assorted lines, intake piping, intercooler, fuel system
Old Oct 15, 2003 | 11:08 PM
TurboedF22A's Avatar
TurboedF22A
What engine do you have? Cause you might need a bigger tubo than that. Also, you have a whole bunch of other stuff to get/look into other than the turbo. For a good start, your going to need to look into fuel/timming managment cause there is a huge market out for that. Also, depending on the turbo, your going to want to look into boost managment like waist gates and B.O.V.'s. Other than that, you just going to have a whole bunch of plumming for your charge pipping and exhaust parts. You could also look into some nessesary guages, i.e. air/fuel, oil pressure, exhaust temp, etc.
Well, hope that was of help to you
Old Nov 4, 2003 | 10:16 PM
sol_1320's Avatar
sol_1320
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
:thumbup:
Old Nov 13, 2003 | 07:54 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Need:
Turbo
Oil lines
Coolant lines ( if it has them )
Charge pipes
Blowoff Valve
Intercooler
some type of fuel management ( s-afc, v-afc, fmu )
bigger injectors if using s-afc or v-afc
a/f gauge
boost gauge
vacuum line
oil fittings
filter for turbo
downpipe made for your car
exhaust manifold ( CX, HF, STD )
adapter plate from manifold to the turbo ( purchased at www.homemadeturbo.com )
did i forget anything???
Old Nov 14, 2003 | 05:33 PM
4thgenlude's Avatar
4thgenlude
http://www.phatwhippincrx.20m.com/contact.html
