eacv problem
Old Oct 12, 2003 | 06:19 PM
shawn_crx8891's Avatar
shawn_crx8891
Default eacv problem
what would cause a check engine light for eacv (electronic air control valve)? i replaced it with a newer one and it still throws the code. reset the ecu when i swapped them too. there is no coolant leaking out of the hoses and it doesn't appear to be broken anywhere.
Old Oct 14, 2003 | 11:28 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Did it just happen one day or happen after seme (any)work?
-PHiZ
Old Oct 15, 2003 | 08:09 AM
shawn_crx8891
it has been like that since i did the swap (93 b18a) a year and a half ago. i replaced the original eacv with one from a 97 i believe. does it have to be non-obd?
Old Oct 16, 2003 | 01:21 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I am pretty sure OBD1 and OBD2 one's are the same, I'm not so sure about OBD0 ones, it might be worth a shot...
-PHiZ
