ls/vtec ecu
Old Oct 9, 2003 | 10:33 PM
SKINNYCARGUY's Avatar
SKINNYCARGUY
Default ls/vtec ecu
for an ls/vtec motor to go into a 88-91 crx what kind of ecu would have to be used? Would some kind of Hondata work? If so what one?
Old Oct 12, 2003 | 11:33 PM
Kai's Avatar
Kai
Rotorphile.
Use a 90-91 PR4 and an RPM activated switch for VTEC control.
You could also use a PR3 or PW0 if you want to run VTEC the right way, however they may run a bit lean.
Old Oct 14, 2003 | 10:54 PM
PHiZ's Avatar
PHiZ
BOOST GOD
How good at wiring are you? I might reccomend keeping the engine OBD1, and maybe getting a hasport OBD0->OBD1 engine conversion harneess and ecu crossover harness.
Then I would run a chipped P28 ecu. Unless you have a GSR manifold with the secondaries, in which case I'd run a chipped P72 (expensive). I'd reccomend ditching the GSR IM if that is what you have.
-PHiZ
Old Oct 14, 2003 | 11:02 PM
Kai's Avatar
Kai
Rotorphile.
Assuming the engine is OBD-1.
What head are you using, and what model year did it come from?
