power window lube
Old Sep 14, 2003 | 06:09 PM
skylane's Avatar
skylane
Default power window lube
What's a good product to lubricate power windows? My Accord windows are gettin' real slow.
Also, should you spray the seals around the edge of the window or try to get the moving parts down inside the door (or both?)
Old Sep 17, 2003 | 06:45 PM
karlt10's Avatar
karlt10
Spraying the edge of the window won't do much for down inside. however, an EXCLLENT treatment for window trim and weather-stripping is spray silicone. You can pick it up at the parts store for a few bucks. It'll have a spray tube and you simply want to spray it around the perimeter of the window, and then on the door & hatch weather-stripping. It will lubricate the rubber and do two things- in Winter it will keep your windows from icing shut, and in Summer it will keep the trim lubed and sealed tight. Just spray a bit onto a rag and wipe it on.
As for lubing the window mechanism, make sure you use a form of LIGHTWEIGHT and SYNTHETIC grease. Your best bet is to ask your local dealer what they use. You want lightweight to prevent drag on the motors, and you want synthetic to prevent freezing and thinning due to water & weather.
kt
Old Sep 21, 2003 | 06:23 AM
agileauto.com's Avatar
agileauto.com
I agree. silicone spray is thumbs up.
Old Oct 28, 2003 | 09:32 AM
gutterslide's Avatar
gutterslide
one more vote for silicone spray.
Old Nov 2, 2003 | 08:48 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
silicone spray works for a little while, go to a honda or acura dealership and ask for something called "shun-itsu" it's grease that honda uses of the window run channels at the factory, it will fix it for a couple of years.
Old Nov 17, 2003 | 12:14 PM
Slick EX's Avatar
Slick EX
OEM to the max!
Hmm I might have to try that Shun ITSU, thanks hondatech. I also use silicone. You might have to do it once a few months, but it beats your windows falling out of the tracks. Warning though, smells funky for a few days lol.
