how do you: change DX guage to EX
Old Jun 5, 2003 | 02:51 PM
lkailburn's Avatar
lkailburn
college kid
Default how do you: change DX guage to EX
i've heard of people installing an EX guage cluster in their DX civic. i have a 97 civic. anyone know how easy/hard it is. and if anyone knows how to, could you please post. thank you
Old Jun 5, 2003 | 03:36 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
first you have to get that black column that is infront of the gauge cluster off,..it is held on by 2 screws that are at the top,..and then 2 tabs that are at the bottom,..once that is off,..there are 4 screws holding on the gauge cluster itself,..once you get those 4 screws,..take out the gauge cluster enough to see 2 harnesses connected to the back,..unplug those,..installation of the new cluster is the complete opposite of the removal of the old cluster,...oh and about those 2 tabs i was talking about earlier,..i just broke those and my black column still goes in with a problem,...sorry its kinda a shitty how to but its a fairly simple install,...good luck
Old Jun 12, 2003 | 05:36 AM
lkailburn's Avatar
lkailburn
college kid
does anyone have a cleaner way to do this? with less breaking.. no offence to you WideBodyEK
Old Jun 12, 2003 | 06:34 AM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
Haynes manual has a decent instruction set on this one. I've had mine out following those instructions... Nothing broke. Follow the instructions. With a little bit of basic knowledge, you can do it easily.
Old Jun 12, 2003 | 09:57 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
he didnt like my with the quickness how-to :wtc:
its aights,...i mean there is away to get the bezel out i just got aggrivated and ripped mine out
Old Jun 15, 2003 | 06:21 PM
lkailburn's Avatar
lkailburn
college kid
what about the tach. are there going to be wires for it?
Old Jun 15, 2003 | 08:42 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
like i said above,..there is only 2 harness plugs in the back of your existing cluster,..unplug those and then plug them in the same spot on the new cluster,...its all plug and play
Old Jun 15, 2003 | 11:10 PM
Kabooki's Avatar
Kabooki
93 Honda Civic Sedan DX
Stock Gauge Pod:
EX Gauge Pod:
Stupidly enough no wire modding was needed, Just pull out the old, plug in the new. It already had everything for the tach, cant imagine that costing too much more for honda to just throw in.
