How To: Paint and Prep OEM and Aftermarket Lips/Skirts
Old May 5, 2003 | 04:31 PM
whoaitslen2's Avatar
whoaitslen2
hermit
A flex coat additive will give the paint the ability to flex without chipping. Same deal to what the adhesive promotor does but instead the additive is mixed in with the paint. Getting either the flex coat additive or the adhesive promotor is a good thing to have to ensure the paint will stick onto the plastic surfaces.
Old May 7, 2003 | 02:23 PM
EddieK's Avatar
EddieK
Default painting side moldings?
i was wondering how i should paint the side moldings.. what sandpaper should i use to sand it? what kinda primer? wut kinda paint? (can i use spray can paint?)
Old May 7, 2003 | 03:30 PM
whoaitslen2
hermit
Check the sticky up top. You can use that as a reference for painting side moldings too. The only difference is you can leave the side moldings on the car and just mask off the doors with masking tape and newpaper. Try to get at least 2 layers of newpaper because the paper might get soaked and the paint might bleed through. Good luck and watch for overspray. :thumbup:
Old May 11, 2003 | 08:11 PM
silvagsr's Avatar
silvagsr
any suggestions on how to trim the edges to make it fit cleaner? I was told to just sand but its pretty then so I figured I could cut a little bit and then sand the rest?
Old May 15, 2003 | 05:23 PM
96GreenCivic's Avatar
96GreenCivic
I just got a Dremel tool and it works great ! You've got cutting disks, grinders and sand drums to finish it off!
Old May 18, 2003 | 11:19 AM
96GreenCivic
Hi I painted my side skirts and they came out great. But to get the skirts off, I had to snap off some of the plastic screws and molly bolts. They didn't want to come off. Does anyone know where I can get a few of those??
Old May 19, 2003 | 09:01 PM
jason78240's Avatar
jason78240
Check out this site....
http://www.autobodysupply.net/w-e/fasteners.htm
....hope it helps !
Old May 22, 2003 | 06:17 PM
96GreenCivic
Thanks for the link. I'll take a look. So when I painted and clear coated my skirts they came out better then I expected, but I wish they came out with some more shine to it. I used Plastikote brand base color and clear coat. Can anyone recommend a clear coat that would offer more shine? I am going to be painting some side view mirrors and I really want them to shine. Do you think the skirts will look better after I give them a coat of wax? I didn't want to wax them yet. I wanted to give them a week for the paint to cure correctly. Thanks for all of your advice.
Old May 23, 2003 | 08:58 PM
jason78240's Avatar
jason78240
Don't wax it yet !!! Wait at least 30 days for the paint to cure. As far as the shine goes, you probably just need to wet sand the paint, then compound it out.
Old Jun 23, 2003 | 06:14 PM
EddieK's Avatar
EddieK
so do i have to put on the clear coat 10 minutes after the paint dries?
or.... can i wait for the paint to dry a couple hours and then add the clear coat?
