Honda Civic 96-00: DIY CTR Headlights Guide(with Pictures)
Old Nov 1, 2006 | 11:09 AM
  #221
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You can try alcohol. Paint thinner would likely do the job as well. I wouldn't sand them...
Old Nov 1, 2006 | 12:17 PM
  #222
PoloSaTiy's Avatar
PoloSaTiy
Default ..
I asked the guy at the auto parts store, he told me that theres no paint thinner for plastic, he said its better to try to sand it, so im going to try to sand it with 1000 Grit
Old Nov 3, 2006 | 03:52 PM
  #223
nukedawhales's Avatar
nukedawhales
Do they have to go in the oven?
Old Nov 3, 2006 | 07:35 PM
  #224
westcoaststyle
It's very difficult if you don't. You need to heat the entire housing equally in order to get the lense off. You might be able to use a heat gun, but I'd be afraid of melting or warping something...
Old Nov 20, 2006 | 08:45 AM
  #225
burner_18's Avatar
burner_18
can this be done to the plastic headlights? for example ive got the jdm integra conversion headlights, but they are the silver types not the black background.. can it be done?
if someone has a write up specific to this thanks..
Old Nov 20, 2006 | 09:20 AM
  #226
westcoaststyle
This DIY was done on plastic headlights...
Old Jan 1, 2007 | 05:37 PM
  #227
ek9az's Avatar
ek9az
PM'ed
Old Feb 4, 2007 | 12:15 PM
  #228
adva7328's Avatar
adva7328
BOOST PROJECT 99
i am sure this was already answered through this forum but i have a set of jdm headlights that are very foggy and the clear has come off of them what can i do to revise these things and what are the steps i am not worried about paintin the inside because they are already the jdm gunmetal color the outside plastic just looks bad thanks everyone
Old Feb 8, 2007 | 08:08 AM
  #229
bonsaitree's Avatar
bonsaitree
check out post 214.....wetsand with high grit paper and buff em out.
Old Feb 8, 2007 | 02:04 PM
  #230
adva7328's Avatar
adva7328
BOOST PROJECT 99
thanks bro but will this even wk if the clear is off the front of the headlight
