How To: Install Angel Eye Headlights
What I do is I wire them to a switch. In case of an emergency I would just be able to switch them off or switch them on whenever I feel like showing. Gte one of those relay switch at radioshack. And as for the black wire, just ground them anywhere so u wouldnt have to drag the wires all the way to ur batteries.
Do you mean the Full Harness to split the beams of your headlight or just the Halos?
The harness is simple. Red Wires go to the battery then only one headlight plug goes into the harness and then the other two plugs go to the lights. Then you ground the plug to the lights..(black wire) to any good ground area it can reach.
For just the Halos it can go to any hot wire you want. Sidemarkers headlight or a switch like they said above.
Hope this helps....
LAtes
Hope this helps....
LAtes
i would def hook your halos to a seperate switch. The little led lights burn out rather quickly if they are on alot. I have a few friends that have them and they have theres on a seperate switch and it works out great
later
Matt
later
Matt
