Misc. Honda/Acura: Black Housing Headlights
Old Mar 1, 2003 | 08:40 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
I used that on my hub caps and my dash pieces looks good :thumbup:
Old Mar 3, 2003 | 08:23 AM
ThaJazz's Avatar
ThaJazz
I did it to my JDM one-pieces and it's definitely worth it. I used the oven technique. 200 degrees, check after 20 minutes. I supposed the higher temp would've worked, but this was better on my conscience. I didn't spray paint, but used my wife's paint brush with exterior paint. Worked out well, IMO.
Old Mar 3, 2003 | 12:58 PM
danatureboi's Avatar
danatureboi
i did this on my del sol and it turned out pretty good but now i cant see anything at night will hids fix this problem
Old Mar 3, 2003 | 01:30 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Well, that's because your del Sol makes most of its light output by using the reflector behind the headlight. If you painted over this, which apparently you did, you're kinda screwed. HIDs would increase light output by a lot, but $500 is a lot to pay. You might wanna try to strip the paint off if you can or pick up a new pair at a junk yard.
Look at what ThaJazz did...that's the point of this exercise. To make the fringes black. Not the whole headlight
Great job Jazz :thumbup:
Old Mar 4, 2003 | 07:13 AM
ThaJazz's Avatar
ThaJazz
Thanks 98coupe! I don't know if paint stripper would work if you made a mistake, though. The reflective portions are tempermental and can peel off with tape. Be careful!
Old Mar 4, 2003 | 11:39 AM
98CoupeV6's Avatar
98CoupeV6
Yeah, I was just throwing something out to avoid telling him that he was screwed.
Old Mar 7, 2003 | 11:47 AM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
I'm in the process of painting mine right now. I'm trying out Tamiya Gunmetal Paint (Code TS-38). It looks great... we'll see how it holds up.
Old Mar 11, 2003 | 05:13 PM
lilboi's Avatar
lilboi
what you could do it spray some clear coat on to it, or even chrome paint. that will make it reflect like new again. you can do both. i would rather not paint that part at all, but if you did it already, your screwed. when you work with DIY's you are bound to run into some problems. I am planning to paint mine, do i paint the bottom of the reflectors too. should i square it off or just go with the round part. Kinda hard to explain, please post some very very close up pictures of the headlights. If any one need's help with DIYS pm me. HAVE FUN
Old Mar 11, 2003 | 06:02 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I know we said we'd have some pics up last week, but we didn't have the paint. I got the Dupi-Color Gunmetal paint from Wal-Mart the other day and we'll be doing this DIY with some pics either this week or weekend.
Pics soon.
Old Mar 15, 2003 | 04:07 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Pics soon.
hurry up :fawk: I want to see this
