94-97 Honda Accord Climate Control Unit Replacement/Dash Removal
Old Jul 19, 2005 | 05:32 AM
baldytheeagle's Avatar
baldytheeagle
Default 94-97 Honda Accord Climate Control Unit Replacement/Dash Removal
Hi
I have a 97 Accord and my Air Con works very intermittently. I purchased a replacement control unit and now have the joy of trying to figure out how to remove the whole dash to put the control unit in.
picture of whole dash/control unit:
the piece i purchased:
Can anyone let me know what I need to do in order to get my new control unit in - or at least remove the dash?
I've diagnosed the AC problem as being strictly the control unit (the relays and fuses are OK and power is going in). I've gotten the 2 screws out from the speedometer/tachometer cluster, and can dislodge part of the dash assembly a bit, but would appreciate some advice.
Thanks so much!!!!!!
Old Mar 9, 2008 | 12:30 PM
chenbo1's Avatar
chenbo1
Default Honda Accord 97 climate control unit installation
Hi: I saw your thread regarding the same subject that I have. I bought the entire climate control unit I just need to know how to disassemble the dash and install it? I cracked the "teeth gear" on my heater control.. It is blowing hot air everyday like talking to another moron.. hhhehehehehehe hahahah Can you help me?
Old Jun 16, 2010 | 07:05 AM
berett315's Avatar
berett315
Hope this helps cuz i have to order and replace mine too for punching the buttons on the climate control , but i bet there is a way to get to it the same way you get to the radio-
*Look inside the bottom of the armrest and there is a square that must be popped open-remove the 2 screws you see there.
*Next, pop out the cup holder and unscrew those two screws.
*Pull out the entire console and set it aside.
*remove the black trim around the shifter and radio, it pops out too once you get the console off
*your guess from there, i havent made it that far-too hot right now to be working in my car
Old Mar 11, 2011 | 09:19 AM
clay's Avatar
clay
i have a 1989 honda civic im putting a h22a1 can you tell me where i can get axels?
Old Jun 27, 2025 | 10:10 AM
daryelcorran's Avatar
daryelcorran
wingzero210
Accord
6
Nov 23, 2007 04:45 PM
RitcheyRch
92+ Civic/EL & Del Sol
2
Oct 22, 2005 08:02 AM
dwillms
2
Mar 5, 2005 11:40 AM
shifty35
4
Sep 16, 2003 04:27 PM
