Hard to shift
Old Dec 30, 2004 | 01:27 PM
airrace's Avatar
airrace
Default Hard to shift
I have recently purchased a 90 Civic DX that is hard to shift. The shifter really feels snug. It works ok, but is very tight to pull.
Is there a shifter cable or linkage or something that can be adjusted??
Is this a common problem?
thanks!!!
Old Dec 30, 2004 | 03:36 PM
Tankard's Avatar
Tankard
Be sure your clutch is engaging all the way. Adjust your clutch cable. If that's not it, try changing the tranny fluid with a thin synthetic oil. If that's not it, it could be your tranny internals are messed up. Or it could be the shift linkage maybe.
