installing SS brake lines in 02 accord
Old Dec 5, 2004 | 11:12 AM
flyromeo3's Avatar
flyromeo3
Default installing SS brake lines in 02 accord
If anyone has done this themselves is it a simple job to DIY?
Is the installation simple to follow meaning disonnect both ends and just reconnect the new lines?
Do I need to bleed the brakes?
I've never done this so detailed help is appreciated.
Thanks
Old Dec 5, 2004 | 11:45 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, you need to bleed the brakes. All you have to do is swap the new ones in. It shouldn't be too hard to install them yourself, you just need to be quick when swapping them because the fluid will continue to leak until you have them connected again.
