interior dash lights not lighting up
Old Nov 28, 2004 | 05:38 PM
91AccordDude's Avatar
91AccordDude
Default interior dash lights not lighting up
yo yo, last night i went out for a drive with some friends and all of a sudden my cluster lights and alarm stopped working , do any of you guys know what's wrong with it? is it a fuse or something i have to replace?
Old Nov 28, 2004 | 05:54 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Are your running lights working? If not you might not want to drive since that will get you pulled over pretty quick. The interior lights usually go out with the running lights and plate lights. And yeah it's prolly just a fuse. Should be a really easy fix.
Old Nov 28, 2004 | 09:03 PM
sno's Avatar
sno
sounds like the fuse for the driving lights.
Old Nov 29, 2004 | 09:14 PM
91AccordDude
yeah, my head lights are working just fine...it's just the dash lights that aren't turning on, and my stereo light doesnt dim when i turn on my head lights too...kinda weird, where can i find the fuse to replace?
Old Nov 29, 2004 | 10:36 PM
augy's Avatar
augy
Go to any drugstore, and they'll usually sell small kits of assorted fuses for a couple dollars. Also, every Honda I've looked at comes with spare fuses in the fuse box itself, so see if those haven't been used up yet. Good luck, I've got wiring problems that I'm working on too
Old Nov 30, 2004 | 01:34 AM
sno's Avatar
sno
yeah, check the fuse box for spare fuses and to replace the possibly burnt one. also, if you're still having problems with the dash lights check the dimmer switch, those things go all the time.
Old Dec 1, 2004 | 01:08 AM
91AccordDude
cool, thanks guys, i'll check them out
Old Dec 1, 2004 | 01:20 AM
bluetwo's Avatar
bluetwo
No problem. What I was getting at earlier, was that the running lights or driving lights which are the ones that come on when you turn the switch once, work with the dash lights, and when turned on activate the dimmer for the radio and clock. Your headlights will still come on without them, but the other stuff wont work,...
Well it could be the fuse, or it could be a short in your dimmer switch. Which I think is on the left of the wheel, and allows you to control the brightness of the dash lights. If the lights flicker when you adjust this switch, then you may need a new one.
Old Dec 2, 2004 | 02:21 PM
91AccordDude
hehe, it was the fuse! only $.35 at pep boys.
i'll keep the dimmer switch in mind bluetwo, just in case something like this happends again! thanks guys
