DIY 6th gen Civic suspension
Old Apr 17, 2008 | 11:05 AM
  #31
IanB's Avatar
IanB
MB4
This is one of the best DIY threads I've ever used! The only thing you didn't touch on was broken bolts and how to deal with them, lol. I had 3 break, ended up having to get new LCA's.
Old Apr 22, 2008 | 11:28 PM
  #32
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Originally Posted by korrapat
Dear, Chimchim.
I want to see you rear sway bar installtion? Could you please show me the picture of fixing. Now i got sway bar from EK9 and want to install in my car; Civic Vti 1999.
Thank you fro your share
I don't have the car anymore... but seriously you just bolt it up. Connect the endlinks to the bar while the bar is off the car, the bolt the mounts of the bar to the chassis, then the endlinks to the control arms. Easy.
Old Apr 22, 2008 | 11:30 PM
  #33
chimchim's Avatar
chimchim
Originally Posted by goldex420
i didnt use a compresion tool i just but the air ratchet on it and ziped it off but be careful that fucker will shoot. it shot across the shop about 10 feet i hightly dout it would stick in a tree homie. slamin civics since 92
I don't like this method because you can potentially bork the threads of the strut shaft and the nut (although the nut is replaceable). Plus, it's just dangerous.
If you don't want to use a spring compressor, then you should use the "leave the top hat bolted to the car and jack the knuckle/arm" method. If I had to do this again, I think I go this route as I think it keeps things aligned better.
Old May 17, 2008 | 01:32 PM
  #34
emad_taha's Avatar
emad_taha
Default asd
i like that
Old Jun 7, 2008 | 07:01 AM
  #35
randomtask77's Avatar
randomtask77
Wanderer
I don't have access to air tools, so I was just curious about loosening bolts.
Could I loosen the top bolts before I jack up the car? I don't know how tight these bolts would be and I don't know if I want to be trying to break bolts loose inside the car while it's up in the air.
Old Jun 11, 2008 | 07:36 AM
  #36
lkailburn's Avatar
lkailburn
college kid
they are only torqued to 25 or 30 some odd ft/lbs. nothing crazy tight so you'll have no prob knocking them off with the car in the air
-Luke
Old Jun 11, 2008 | 07:44 AM
  #37
randomtask77
Wanderer
-Luke
Thanks, I appreciate the help. I'm gonna try and tackle changing out my suspension myself. The rear seems really simple. From what I gather, it seems like three bolts (maybe four) to remove the entire shock/strut from the car.
Old Jun 11, 2008 | 10:27 AM
  #38
lkailburn's Avatar
lkailburn
college kid
both front and rears are VERY easy. two bolts on top, two bolts on the bottom. the problem is rust, depending on where you live.
i just installed my koni/gc setup. very happy with the quality of the parts. very unhappy with the total lack of shock travel at any decent amount of lowering. time for some modifications (top hats, fork trick)
-Luke
Old Jun 11, 2008 | 11:45 AM
  #39
randomtask77
Wanderer
-Luke
Did you end up needing an alignment after you were done installing the new suspension?
Reason I ask is because I just had an alignment done to the car after I got the P/S rack installed about a month ago and was wondering if I need another one after I install my own suspension.
Old Jun 11, 2008 | 11:51 AM
  #40
lkailburn's Avatar
lkailburn
college kid
rule of thumb is yes.
i sort of skipped that on the last suspension install but even daily driven i really didn't notice any out of alignment for the few years i had that setup. even camber wear was on the mild side. i should take it in and have it done this time for safe measure, also need to get the tires rebalanced(my calipers didn't clear the wheel weights :P )
-Luke
