DIY help with streetglow underbody neon
man this is gonna be long, did one a few montsh back for a friends friend. TO be honest, its a bitch to do if ur shop doesnt have a lift. I did this at another friends garage and used jacks to lift the car up so it was easy to work with. kk straight to the point. Connect all 4 neons - sounds simple, but its not. Remeber to drill pilot holes then use proper mounting screw. you dont want to use self tapping in this situation. Some become loose. Drill then screw. Run wires along non moving parts and tape it to whatever. After u use electrical tape, Rip tie it. To get power, hide the Streetglow power module under ur dash area. The power, tap it off ur ignition harness. Look for a wire that shows constant 12v. From the 12 volt, fuse it at 15 amps or what is shown on the back. To a SPST switch to control on and off. and from the switch to the power module. Ground it to a good part on the chassis. If u have any more questions just reply back on the forum or PM me.
you will need to drill for the wire from neon tube to power module. Using a metal drill bit, drill into the cabin area, make sure the area u drill is clear. Also use proper grommets and then if u want to make sure its sealed, u can use some caulking thats flexable.
Let sleeping dogs lie.
The consensus has been reached; let's not re-hash the whole argument again..
:closed:
:closed:
