has this been done before??
Old Oct 16, 2004 | 12:34 PM
twentybrew's Avatar
twentybrew
Default has this been done before??
i plan to swap a 91' integra B18A1 w/ tranny into a 93' civic si. i have the complete donor car. but, is there anything that the donor doesnt provide that i might need for the swap?
Old Oct 17, 2004 | 12:42 PM
TekScream's Avatar
TekScream
Worms For Mayor
yes it's been done before. quite a few times. i take it that you're going all motor, due to the fact that thats just a j-spek b18b1. as for things you'll need, well look it up. you're gonna need alo more than just the motor and a tranny. you might wanna consider getting the ecu, linkages & axles, unless you have cash to get other than stock shtuff. gl
Old Oct 17, 2004 | 04:41 PM
lgbr's Avatar
lgbr
Wal-Mart Shopper
You're not going to pass any emissions tests if you do that.
Old Oct 17, 2004 | 07:31 PM
Kai's Avatar
Kai
Rotorphile.
It's been done hundreds of times. You'll need to reuse your D-series wiring harness and injectors and swap to a 92-93 B18A or 94-95 B18B distributor for OBD1 compatability. You also need a cable/hydro conversion kit if you want to use that trans.
It depends on the state.
Example:
California: they'll fail you for having an engine older then the car.
Virginia: they'll fail you if it doesn't pass the sniffer (which it will.)
Florida: if the car has four wheels, it's legal.
Old Nov 5, 2004 | 08:30 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Yeah, I don't know where you live, but it is not suggested you stick an old motor in a newer car. It is usually the other way around.
Old Nov 5, 2004 | 10:10 PM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by TekScream
yes it's been done before. quite a few times. i take it that you're going all motor, due to the fact that thats just a j-spek b18b1. l
:eh:
knowing what you are talking about > you...
Old Nov 6, 2004 | 01:11 AM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by b16aEGcivic
:eh:
Good point. The B18B was only availible as J-spec (note the "C" in speC!) in the ESi model... considering we are talking about the B18A, you make no sense, since the B18A was NEVER (!) availible in Japan as a stock engine.
Old Nov 8, 2004 | 07:37 PM
honura's Avatar
honura
Seni
Your gonna need the following from a 94+ Integra.
ECU
Linkage
Upper driverside mount
Rear mount
Upper Tranny mount
Distro
Things needed from your civic.
Lower driverside mount
Lower Tranny mount
Harness
Injectors
Things you can use from doner.
Motor
Tranny
Axels
I think that is pretty much it. Hope everything you will need hope that helps.
Just incase you wanna know why you need your stock harness, and injectors plus a 94-95 distro from a integra is because these are all OBD1.
Old Nov 12, 2004 | 03:26 PM
BrianDB1's Avatar
BrianDB1
40 Below Summer's Child
OVD0 < OBD1... the wiring is going to **** you.
