Honda fluids only?
Old Sep 17, 2004 | 06:20 AM
AndyOhio's Avatar
AndyOhio
Default Honda fluids only?
Which systems on my Honda cars won't automatically self-destruct if I use a high-quality, non-Honda fluid? I have a 92 Accord 4 cyl, and a 98 Civic 4 cyl, both automatic.
My 92 Accord manual says Dexron II or Honda ATF is recommended, so it looks like I can use some Multi-Vehicle Penzoil ATF in there. Penzoil ATF states that it is Dexron II-compatible and specifically says that it is for use with Honda vehicles.
The 98 Civic manual is more ominious. It states that any non-Honda fluid should be used only as a last resort and flushed out with Honda stuff ASAP! But, I would like to use some Castrol LMA brake fluid, since it has a higher dry and wet boiling point than the Honda stuff.
Thanks!
Old Sep 17, 2004 | 07:24 AM
wedley2's Avatar
wedley2
bboy Wesley West
for tranny, always use honda or above like redline or gearmesh or royal purple. motor oil, i use like castrol? or somthing and a fram filter but i change every 2500-3k since i dont drive much but hard. brake and clutch fluid, i used some cheapy dot 3 stuff. you can use cheapy windshield wiper fluid, hahah.
not sure about coolant.
Old Sep 17, 2004 | 09:37 AM
JimBlake's Avatar
JimBlake
Power steering fluid needs to be Honda, but there's other brands that sell fluid "for Honda" clearly marked on the bottle. That's the one where you don't want to use 'normal' PS fluid.
Anti-freeze should be non-silicate, but ???
Brake fluid isn't special. Don't use DOT5 silicone, but that's true for pretty much every car.
ATF seems to be special, but I don't know how much different it really is. Dexron...?
Hondas use the same blinker fluid as Ferrari & Porsche.
Old Sep 17, 2004 | 10:23 AM
AndyOhio's Avatar
AndyOhio
Cool, thanks, I live near an airport and usually flush the blinker fluid with some prop wash.
Old Sep 17, 2004 | 10:44 AM
JimBlake's Avatar
JimBlake
Hopefully it's genuine Hamilton-Standard!
Old Sep 17, 2004 | 01:23 PM
wedley2's Avatar
wedley2
bboy Wesley West
oh yea, power steering has to be honda, is this a joke but whats blinker fluid? lol
Old Sep 17, 2004 | 04:55 PM
TekScream's Avatar
TekScream
Worms For Mayor
hehe thanks peoples...
Old Sep 17, 2004 | 09:02 PM
AndyOhio's Avatar
AndyOhio
Get the synthetic stuff and change it every 150,000 blinks or every 300,000 winks, whichever comes first...
http://www.kalecoauto.com/fluids.htm
Here's the official DIY:
http://www.geocities.com/changeyourblinkerfluid/
Old Sep 17, 2004 | 09:09 PM
AndyOhio's Avatar
AndyOhio
I decided to go with Honda ATF, and Valvoline Synpower brake juice. Blinker fluid is AOK and good for a few more thousand blinks.
I'll give away the Penzoil ATF to some poor GM owner. :chuckles:
Thanks all!
Old Sep 20, 2004 | 08:58 AM
JimBlake's Avatar
JimBlake
Um, yeah. That was a joke...
