DIY spring install BIG PROBLEM HELP
Old Jul 13, 2004 | 06:27 PM
ChassisInnovations's Avatar
ChassisInnovations
HAN Authorized Vendor
PB Blaster works well...
-Jeff
Old Jul 13, 2004 | 06:37 PM
FA9S8U's Avatar
FA9S8U
You should buy some new shocks!
Old Jul 14, 2004 | 07:39 AM
SonicGSR98's Avatar
SonicGSR98
Shadow Lurker
If you have access to air tools, you can do the two tire trick:
Place the strut assembly between to 14" wheel assemblies with the air gun on the strut. Then make sure the twheels are snug against the back of the gun and the bottom of the strut. Then hold the strut with your foot and give 'er heck! Should spin the nut right off and the wheels will keep the strut from flying off and killing someone. Good luck!
Old Jul 15, 2004 | 10:31 AM
ninjaboy740's Avatar
ninjaboy740
Originally Posted by Jason852001
Right now I am in the process of installing some coil overs on the back of my civic. I have ran into what seems to be a pretty big problem, the allen screw on top of the strut is stripped so does anyone else know of a solution to this problem?
Ok this happened to me too when I was installing new shocks and springs. Luckly I had an extra strut just sitting around, but I'm guessing you're not that lucky. Anyway, I found that having a strap wrench, you know the ones that they have for opening pickle jars and tightening pipes and things like that, was the best way to hold the shock rod while you wrench off the locknut on the top of the strut. Oh and please make sure you have a spring compressor to compress the spring while you are doing this. 2 tires on either side of the strut doesn't sound safe to me. Oh, and I had to crank pretty hard on the top nut so I would also suggest air tools, just makes the job easier. Hope that helps.
