Replacing Clutch Master and Slave Cylinders
Old Apr 30, 2004 | 05:21 AM
Rab's Avatar
Rab
Dumped4life
Default Replacing Clutch Master and Slave Cylinders
Do I need a flare wrench to get the fluid lines off. And is there anything else special that I would need?
Oh if I do need a flare wrench can you please give me the size that it needs to be (?mm)
I have a 1994 Accord EX btw.
Old May 8, 2004 | 08:28 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
I would use a flare wrench, open ends will strip the tube fitting.
I think the size will be 10mm, maybe 12mm. If your buying the tool get a 10-12mm combo flare wrench, this will work on most hondas for everything tubing wise. The bleed screw is a 8mm I believe. Other than that, it's pretty straight forward.
Old May 17, 2004 | 10:16 PM
zuczek's Avatar
zuczek
What were the symptoms that you need to replace the master and slave? I have a 94 Accord EX and the pedal goes all the way to the floor and stays there. I flushed and bleed the system but it comesback in a week or so. IS that master or slave cylinder issue?
Was it hard to change the master cylinder? Slave looks easy.
Old May 18, 2004 | 08:57 AM
hondatech's Avatar
hondatech
It's leaking somewhere, either internally or externally. You need to find out where. If you can't just replace both of them.
Old May 18, 2004 | 08:58 AM
hondatech's Avatar
hondatech
Check behind the clutch pedal inside the car the master usually leaks there.
Old May 18, 2004 | 02:22 PM
zuczek's Avatar
zuczek
I will check tonight. Thanks hondatech.
Old May 19, 2004 | 06:32 PM
lilboi's Avatar
lilboi
changing both cylinders are really easy. I bought them both from my local shop (kragen), and installed it. I push the clutch and it droped all the way down to the ground. I saw a leak on my slave cylinder. But i changed the master cylinder just cause i don't want it to give me problems later. I suggest you do that. You don't need any special tools, just your wrenches and rachets (maybe some small hands).
white_n_slow
Do It Yourself
11
Apr 1, 2010 11:22 PM
highmileage
Prelude
3
Mar 30, 2004 05:34 AM
teggypower
9
Feb 24, 2004 12:16 PM
AwwsChwA
Engine Swaps, Tech & Tuning
3
Apr 15, 2003 11:17 AM
98CoupeV6
Do It Yourself
Jan 17, 2003 05:11 PM
