Mounting tires?
Old Apr 8, 2004 | 07:08 PM
RboYi's Avatar
RboYi
Default Mounting tires?
k, im a Junior in HS, n my school has all the tools n crap, i got new wheels and tires, low profile (40) tires. today i've had hell of a lot of problem moutning the tire on the rim, scraped the rim a little bit too.. not good. and my teacher is a dick, he wont help us, and when he does it, it seems so easy. does anyone have any suggestions? put a lot of weight on the side already in?
Old Apr 11, 2004 | 06:51 PM
drive4show's Avatar
drive4show
Yeah, I wish someone had told/showed me the "trick". The directions that came with my tire mounter were not very clear.
If you look at the outer edge of the rim, there is a "step" on which the tire bead seals. Moving towards the middle of the rim, there is a second "step". For the side of the tire that's already mounted, you need to push down the tire edge down into that second "step". That's what gives you enough slack to get the other side of the tire over the edge of the rim.
Once I figured it out, it took about 5 minutes total to mount the tire.
Good luck.
Old Apr 29, 2004 | 09:28 PM
XSrcing's Avatar
XSrcing
you have to make sure the drop center (second step) is on the top when you put the rim on the machine. if you are having a hard time getting the tire into the drop center, try using the bead bar to pry it into the drop center.
you should practice on some tires that arent low profile first.
Old Apr 29, 2004 | 10:44 PM
drive4show's Avatar
drive4show
Wow! Figures there's a name for that: drop center. I learn something new every day.
Old Apr 30, 2004 | 12:16 AM
wait hasnt that always been the name of it? then again im not too sure, i was kicked out of basic auto for missing it 135 times oh well....they still let me use the tools at school and yes pelase do practice on tires that arent low profile...rims with low profile tires a bitch to take off....atleast in my opinion....i practiced on shitty rims and tires first....then i moved to low profile...and i still managed to scractch my wheels...oh well.....u live and learn
Joao
Oct 6, 2003 11:50 PM
smakdown
Accord
8
Jul 24, 2003 08:05 PM
Wild0ne21
Jun 9, 2003 09:50 PM
dnt94civic
May 24, 2003 09:24 PM
