Immobilizer to PCM signal error problem HELP!!!!!!!!!
Old Mar 27, 2004 | 10:31 AM
pimpincl's Avatar
pimpincl
Default Immobilizer to PCM signal error problem HELP!!!!!!!!!
My check engine lite came on and showed up P1259(same as above) and everyone wants to charge me 100.00 to tell me what's wrong . Can anyone help PLEASE?????????????????????????????
Old Mar 27, 2004 | 04:24 PM
IntegraR's Avatar
IntegraR
tell me the year, make, model and engine of the car and i will see what i can do... i have some access to a website with all manuals... very helpfull my shop gave me access.... i will be checking soon for your reply
Old Mar 28, 2004 | 07:46 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Anything to do with the immobilizer, I'd take it to the dealer first, because that is what any other mechanic is going to tell you.
No point in paying $100 bucks or more to a mechanic, just to find out they can't do anything, or worsed, dicked around and wasted your time.
IMM sends a signal from your key cylinder to your ECU, it's an antitheft feature, japanese ECUs don't have this feature, from what I know.
-PHiZ
Old Mar 29, 2004 | 08:06 AM
IntegraR's Avatar
IntegraR
bump....
Old Apr 1, 2004 | 12:53 PM
pimpincl's Avatar
pimpincl
1999 acura cl 2.3
Old Apr 2, 2004 | 09:56 AM
IntegraR's Avatar
IntegraR
here is what i found...
Code: P1259
A problem in the VTEC Pressure Switch circuit or VTEC Solenoid Valve circuit
good luck fixing it
how to clear the codes when you fix the car???
1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
2. Turn the ignition switch OFF.
3. Remove the BACK UP fuse (7.5 A) from the under- hood fuse/relay box for 10 seconds to reset the PCM. ( back you fuse is on the last Thumbnail i attached....)
File Type: gif
File Type: gif
File Type: gif
File Type: gif
Old Apr 5, 2004 | 11:19 AM
pimpincl's Avatar
pimpincl
Thanks alot!! I've noticed that when I take a sharp turn to fast the engine kinda sputters like there might be a pressure problem, and as I striaten out the car s vtec kicks in.
Old Apr 7, 2004 | 09:16 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Save yourself some time and pull off the vtec solenoid and clean out the screen inside. You probably have some sludge build up in the screen which blocks Vtec oil pressure. It's pretty common.
con4me
92+ Civic/EL & Del Sol
2
Jul 15, 2003 05:10 AM
Louie002
Jun 10, 2003 01:44 AM
Jimd118
2
Dec 9, 2002 04:54 AM
oc_civic
7
Nov 13, 2002 03:44 PM
caylan
Engine Swaps, Tech & Tuning
2
Oct 6, 2002 06:53 PM
