Shave Emblems & Fill In holes
Old Mar 16, 2004 | 09:16 PM
RboYi's Avatar
RboYi
Default Shave Emblems & Fill In holes
Hey I shaved all of my emblems off and I have a buncha holes everywhere, how do i fill them in? And paint? thanks
Old Mar 17, 2004 | 08:03 AM
DRAG 3 INTEGRA's Avatar
DRAG 3 INTEGRA
Drag # Integra
u might want to go to a body place man
Old Mar 17, 2004 | 11:05 AM
ReVenGe's Avatar
ReVenGe
(singing) bondo, best friend....
take some electrical tap and put it behind the whole if you have acess to it, the shove bondo in so that it pushes the tape out and creates a seal.... hopefully your -skilled enough to not have acces on top and need to sand in which case you will need to paint......
Old Mar 17, 2004 | 01:51 PM
integradraggin's Avatar
integradraggin
you can use bondo but I would use kitty hair on it first. it is pretty much fiberglass in a can. Fill the kitty hair in from the back letting it ooze out the front, wait 20 mins or a little longer, then sand. After it is smooth use bondo. Smooth it down and fade it into the rest of the paint. Prime, paint, and clear and you are done. This will mostly work with everything you would want to shave, except for door handles, key holes, and bigger objects. If you want to know how just let me know
Old Mar 18, 2004 | 03:25 PM
elementliquidx's Avatar
elementliquidx
so u can do this with door trims too? and for the door trim pieces can u jus pry em off?
Old Mar 18, 2004 | 08:25 PM
integradraggin
yeah on the door you can do the same thing. To get them off depending on your car take off the interior door panels, after that you will see about 4 clips on each door. this is for the door trim. I messed mine up instead of taking my time but ohh well i never will need them again. On the holes that are left you will want to take a hammer and tap and from the outside of the door gently tap the 4 sides inward. you dont have to do it to much but this will help later.
Derek
Jun 29, 2003 08:41 PM
ACCORDDUST
Accord
5
Nov 26, 2002 01:42 PM
Rycechyk
Accord
Sep 17, 2002 07:32 AM
howiedoit
Aug 22, 2002 09:21 AM
k.a.y
92+ Civic/EL & Del Sol
Jul 24, 2002 04:50 PM
