3 - 5 angle valve job
Old Feb 18, 2004 | 09:17 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
Default 3 - 5 angle valve job
What are the procedure to do thise job your selfes? how would i go along on doing this? i have a extra b16a head im willing to learn on. anyone can help i would really appriciate it. especiall if yo have some pics
Old Feb 27, 2004 | 03:55 PM
RiGgEdB18B1's Avatar
RiGgEdB18B1
B18B1 is the best!
nope ,take it to the machine shop that specailizes on that....save sum money and get it done not very expensive.
Old Mar 1, 2004 | 03:15 PM
ExiledinIN's Avatar
ExiledinIN
I took an engine class for fun at our local college. We used a special grinder to set the angles in order to do it. I'd be real skeptical about a DIY w/o the proper equipment.
I've read from one of the port and polish company's website that said that a 5 angle did not buy much in terms of performance.
If I remember which one, I'll post a link.
Old Mar 4, 2004 | 04:24 PM
ExiledinIN's Avatar
ExiledinIN
http://www.alaniztechnologies.com/headterms.html
Look under the MULTI-ANGLE VALVE JOB section. I'll cut it in here.
A multi angle valve job is the cutting or grinding of 2 or more angles on the seat and valve. The purpose of a multi angle valve job is to improve airflow. By now you have probably heard of 5 angle and radius valve jobs. The truth…… this is more applicable in the American iron heads. There just isn’t enough material in the small diameter seats or valves to see any real noticeable differences on a flow bench. A .5% gain maybe seen on a flowbench but the flowbench has a plus or minus error factor that has to be eliminated before a true flow figure can be attained. Older American iron heads may benefit from a five angle or radius valve job but only because the head is so bad to begin with. The Honda head is diffrent. Our flowbench testing has proven time after time that the correct angles and angle widths is what’s important. More CFM gains have been made through this procedure than applying 5 angles or radiuses.
Old Mar 4, 2004 | 08:00 PM
qtiger's Avatar
qtiger
Valve jobs cannot be done by hand. Period. The end.
ChrisGSR
Engine Swaps, Tech & Tuning
7
Apr 22, 2003 05:21 AM
vtecaccord01
Accord
21
Mar 28, 2003 10:13 AM
pyrovtec
Oct 17, 2002 05:03 PM
whiteinte95
4
Sep 21, 2002 12:10 PM
Pfieffdog
Aug 30, 2002 04:10 AM
