How To Tighten Up E-Brake?
Old Dec 21, 2003 | 06:58 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
For the fourth gen.
f you remove your consoe by te brake lever you will notice a pair of cables beneath it with adjusting nuts on them....tighten these a little at a time (1 or 2 turns) then test the tension and test spin the car to make sure it isn't dragging the brakes.
defvayne....if you do not know then do not post BS comments like that because that can do more harm than good and its just plain messed up to give bad advice like that.
Old Dec 21, 2003 | 07:00 PM
wedley2's Avatar
wedley2
bboy Wesley West
lol, maybe i wont go wit his idea and follow niteshades. i think my car is fine becuz i heard you wouldnt have to adjust if ur e-brake clix between 4-8 and mines at 6. so thx for the info.
Old Jan 2, 2004 | 11:22 AM
JimBlake's Avatar
JimBlake
The reverse business is for lots of older cars with drum brakes. I don't know if Honda drum brakes self-adjust like that, but the EX has rear disks. They self-adjust by pulling the handbrake many times, you don't have to be moving.
Like I said, the adjuster nut in the console is for stretched cables. If the auto-adjust mechanism is screwed up, it won't help to adjust the cables.
Old Jan 13, 2004 | 03:39 AM
Knightmare69's Avatar
Knightmare69
Hater
Which EX are you talkin bout? My gf's 98 Ex has rear drums.
Old Jan 13, 2004 | 07:22 AM
JimBlake's Avatar
JimBlake
Our '98 Accord EX has rear disks. My Helm book agrees...
I think either your gf's car isn't really an EX, or it was used as a donor car for someone who wanted rear disks.
Old Jan 13, 2004 | 09:32 PM
Samson's Avatar
Samson
chris is the devil
was it from canada? being in NY... not too far. that would mean its the US LX.
Old Jan 14, 2004 | 06:43 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
She either has a DX or an LX 4 cylinder.
Old Jan 14, 2004 | 08:39 AM
chrisexv6's Avatar
chrisexv6
Or the SE..........only drum brakes in back (makes no sense to me either, I cant understand why they would bother making two sets of brakes for the same car). Good thing you get a sunroof though, that makes all the difference (EDIT: my bad, Edmunds says SE wasnt avail. in '98).
And the "use reverse to self-adjust" thing used to work on drum brakes. It still probably does, except most cars dont have drums in back anymore. Accord rear drums are probably the same as everyone elses, they have the little spur thing that pushes the pads against the drum. Thats the self-adjuster, and it adjusts itself while in reverse.
-Chris
Old Jan 16, 2004 | 03:09 AM
AngryNerdRock's Avatar
AngryNerdRock
this space for rent
so i can just pump the e-brake a couple of times to adjust it? and that would also get rid of the "brake" light on the cluster?
Old Jan 19, 2004 | 07:08 AM
shifty35's Avatar
shifty35
My 95 EX has rear drums. Only the models with ABS have rear disks, I believe. I've always heard to pull the parking brake in reverse to adjust the parking brake as well. But every other way suggested should work.
